Enable RSMLT Edge support to store the RSMLT peer MAC and IP address-pair in the local configuration file and restore the configuration if the peer does not restore after a simultaneous restart of both RSMLT peer systems.
If enabled, peer MAC and IP information for all RSMLT-enabled VLANs is saved after you next use the save config command.
RSMLT Edge support configuration applies to both IPv4 and IPv6. You do not configure IPv4 and IPv6 separately.
The RSMLT Edge support default is disabled.
    enable
    configure terminal
  2. Enable RSMLT Edge support:
    ip rsmlt edge-support
If you have enabled RSMLT Edge Support, disable the feature as follows:
Switch:1(config)#no ip rsmlt edge-support
